tyre size help!
Crimson_27
East Anglia
So I realize this is another Tyre size thread but i'm beginning to go round in circles and need some help from the experts here.
I've got a set of 18'' 8.5j all round, i'm thinking of going 245/35 all round square or 235/35 fr and 255/30 rear. I could be miles away with these so hopefully someone can confirm or put me right. It would be much appreciated.
or just share what set ups you guys run or have worked.
thanks :thumbsup:
Tricky one to get right with so many variables but personally I would go 235 40 front / 245 40 rear depending on offsets
Appreciate the reply, there's almost too many variables !
Is this a set up you've used before?, I just want to avoid upsetting the handling etc too much.
Without offset numbers you cannot tell anything.
Personally i would keep 225/40 front & get a 235/40 rear tyre close to oem (and the design of the car) no extra weight from bigger wheels & rims and a spot on speedo.
ok thanks :thumbsup:
Think ill go for the slightly wider rear as you said initially, (I realise there's no one correct answer as it were).
Is your car lowered ?
If not you could even run M spec numbers of 225 45 18 / 255 40 18 on those rims
No its not lowered ... yet (maby future mod lol) .... so much choice, but thx give me something to aim for. I have a feeling 225/45 and 255/35 are what i run currently on the ellipsoids.
Our Z is set up with 225/40 front and 255/35 Rear but they are 8.5 and 9.5 with an offset of 35 front 40 rear
