scooobydont said:
I am running 255 35 18 rears and 225 40 18 fronts, tyres are Hankook. Car is an E85 3.0i. Can any recommend what tyre pressure I should have? I have had a google and answers seem to vary quite a lot. I am currently running 36 in the rear and 34 in the front.
The key question here is are you running runflats or not. If you are I would stick to what the handbook says. If not pressures closer to the M models are more appropriate F30 R32. As a lower front tyre pressure is used to induce a bit more understeer I went with 32 all round on non runflat M size tyres (same width as yours but 40 instead of 35 on the rear and 45 instead of 40 on the front).
