Sticks said:I don't know but perhaps it depends on the tyre you've replaced them with. Goodyear GSD3s for example, have, I'm told, a softer side wall (as did my Sportcontact2s I suspect) which will affect what pressure feels right..
Maybe I'm an idiot (most probable) - I think the German's provide this information?Tommo said:Not as straight forward as I thought. I went for 33 all around in the end.
My pressures were all over the place!
Front - 35 - 33
Rear - 24 - 45![]()
The car feels so much better over bumps in the road now. Feel stupid for not checking this sooner!
Can someone confirm what tyre sizes my car should have, its got the 108 5 spoke alloys (18inch).
.Tommo said:Can someone confirm what tyre sizes my car should have, its got the 108 5 spoke alloys (18inch).
AlanL said:I disagree - run with the pressures recommended for the ///Ms with non RFT. On our side of the pond where we measure in PSI that would be about 32psi cold on all 4 corners. The RFT pressures are far higher and not appropriate to the non RFT sidewalls at all.
davidmbell said:I think before I was running at
38psi front
45psi rear
Which does seem silly high.
Now on 32 front 38 rear
Any tips?
David
