Tyre Pressure warning light not going out
Greeno
 St ives, Cambs.
OK folks, any ideas on this one...
The pressure warning light flicked on. I had a puncture about 18 months ago and it has started to fail so i know which one was causing it to ping. check the pressure on all of them anyway.
Now when i try and reset the light i get the amber then it doesnt extinguish, it goes red again.
All i can think of is a faulty sensor but i am not entirely sure how these things work.
Any ideas anyone?
There are no sensors in the European Zeds. The system works from the ABS and monitors the difference in rotation between wheels on the same 'axle'. A loss in pressure causes the wheel to rotate at a different speed from the other one. Are you driving the car after you press the button? The system can only reset as the wheels are rotating.
as said above. you need to fix the problem then drive around a bit for it to calibrate. then press the button and it should go away if all checks out.
