I've had my Z4 20i M Sport (auto) for a few weeks. I wanted to check the tyre pressures to make sure everything is in order, but first need to determine what the correct tyre pressures should be. I took readings from the tyres as they are now and get 40 psi on the front and around 43 psi on the back (according to my foot pump). This seems higher than the sticker inside the door indicates. I interpret that diagram as 33 psi on the front and 41 psi on the rear.
The code on the front tyres is "225/35R19 88Y" and on the rear tyres it is "255/30R19 91Y".
Does anyone know what the pressures should actually be (for normal driving, conditions, etc)?
