mmm-five said:The tests are carried out, and reported by the manufacturer, so is purely subjective and only really useful for comparing tyres from the same manufacturer.
It's a self-certification system (for now), and there are 'strict guidelines' set for running the tests...but it's still up to the manufacturer how they perform that test, and it's quite simple to slip your product up/down a grade as necessary to make your performance/expensive tyre seem much better in comparison to the cheap one (e.g. some will run the braking/handling tests at 20 degrees and others at higher & lower temps - which will have an effect on the results).DrNick said:Interesting - are the tests not carried out to a similar protocol/standard?
It makes the consumer believe they're getting the information they need to make a decision, in an easy-to-use format.sars said:mmm-five said:The tests are carried out, and reported by the manufacturer, so is purely subjective and only really useful for comparing tyres from the same manufacturer.
Then it's pretty useless then :thumbsdown:
