Turner RTAB and KW V3s?
pHilli0
 Bedford
I am saving for some KW V3s later in the year. Is the Tuner RTAB kit and OEM bushers worth doing regardless of upgrading to V3s?
Yes will prevent rear arm movement under load (which causes more toe in I think). I've got it and probably best bang for buck mod you can do. I did this over the poly bushes as I didn't want the ride quality to change (ride quality is already quite harsh!!)
Quick question on the subject:
I have this kit on now for 2016:
https://www.ebay.com/itm/401130364371
Also new Eibach springs which were put on at the same time.
I must say the rear feel less planted than before. Any undulations accelerating out of a bend will give me a "floaty" feeling. Why is this? Are the M bushes special to the std e46 ones that are appearantly in the kit?
The alignment show 2mm toe in and 2deg camber at the rear, seems normal.
