Turner Motorsport Power Pulley Upgrade Kit
scorcher
 South Croydon
I need to change the belts on the car, and wondered if this would be worth having fitted at the same time?
http://www.turnermotorsport.com/p-392-z4-2530-turner-motorsport-power-pulley-upgrade-kit.aspx
Will it make a noticeable difference?
Z4 only has one belt, and those pulleys looks like waist of money
Sent from my LT18i using Tapatalk 2
Btw, oem pulleys are aluminium and weight next to nothing
It's not the weight, it's the smaller diameter of the pulley that releases a few horses due to the effect of lowering/raising the gearing (depending on which way you look at it).
As used on our racecars and street cars, these are engineered not only to be the best pulley kits on the market but also to provide the best compromise between performance and reliability. Specifically, we have designed them to underdrive the water pump, and the alternator*. The Z4 has electric power steering and therefore does not need a third pulley. Adding these is like getting FREE HORSEPOWER - there are no downsides and underdriving each of these accessories has been proven safe through years of on and off-track use. We do not believe it is safe to change the crankshaft pulley due to the potential harm to the crankshaft. These kits provide a 10%-20% overall reduction in driving your car's systems and have been dyno-tested with a gain of up to 11hp.
Kit includes water pump, alternator pulleys, and belt. The Z4 has electric power steering and therefore does not need a third pulley. The T-6061 hard anodized aluminum pulleys account for a 10 to 20-percent decrease in accessory speeds, reducing the load on the engine but still maintaining a safe margin for reliability on all components. Installation involves removing the fan for easy access to the front of the engine. The main drive belt comes off easy and each pulley is mounted with Allen head bolts. Typical installation time is 1.5 hours. New main drive belt is included. The pulleys were good for 10.7hp at 6960 rpm and 8.1 lb-ft of torque at 5550 on the 1995 M3.
Not great reviews here...
http://www.zpost.com/forums/showthread.php?t=472282&highlight=pulley
...so unlikely to bother
