So back to the Z4 from hell. Current situation is that I have ABS, DSC, Parking, and Brake warning indicators on the dash. Running a fault scan reveals the following errors
EMF (parking brake control unit)
6032 Control Unit: Supply Line
6570 Interface DSC
DSC
5F55 Internal, Car Access System
5EFC No vehicle-type data, clear fault memory
60AE Run Flat indicator; initialization implausable
For context the EMF was recently replaced after the last unit failed to enable/disable the parking brake via the parking brake button. It HAS NOT yet been coded to the car. The new EMF unit does indeed engage/disengage the parking brake.
Thinking that this issue was a bad DSC/ABS module, I purchased a used one from ebay which claimed to be working (it was oh so very clean on arrival). This is the unit that is currently in the car and presenting these errors. NOTE - These errors where all still firing when the old EMF and DSC units where in the car so the replacement had no effect on the warning/fault lights and codes.
My next thought is that my wheel speed sensors are bad, however prior to replacing the DSC unit I took the car out and read the datastream which indicated all four wheels returning valid speed values. NOTE - I do have a Tire pressure warning indicating a flat/low pressure on the rear drivers side tire.
I also back-probed pin 7 of the EMF unit and am reading 6 volts. I have an oscilloscope on the way to validate the FM signal that the DSC SUPPOSEDLY sends to the EMF indicating the average speed of the rear wheels. I don't have much faith that this is going to reveal too much however although my thought was that this would be a 2.5V signal (but I think that's just for digital Flex CAN signals).
So there's my situation and issue. I am kinda in a pickle as everything seems to be on the up and up, but I am left with these fault codes. Blech.
One more thing - I DO have one of the brake lights out currently (rear passenger side). I don't know why that would trigger the issues, but reading into the ABS system, the Brake Light switch does indeed play a roll in the EMF and DSC operations... could it be all caused from a single bad bulb not completing the circuit?!
6570 Interface DSC
DSC
