treating my car
mac27040
Veteran
 Shepshed
Well it that time of year so i have treated my car:
1. cleaned K&N cone filter and fitted outer protective cover
2. changed spark plugs
3. Changed oil in supercharger (has to be done every 7500 miles)
4. ordered castrol edge 8 litres should be here mid week :thumbsup:
5. ordered K&N oil filter again should be here mid week :thumbsup:
I'd say that your car might feel a little short changed if that's treating it. Then again it's already had a lot of treats bestowed upon it. :thumbsup:
Looks like you're running a Vortech? How much is the oil each time and is it an easy job? I believe they have a permanent drain line attached? I'm thinking of supercharging mine next year so any first hand experience comments welcomed.
All beyond normal service intervals can be said to be treating your Zed :D :thumbsup:
Know what you mean - It's a good feeling maintaining your Zed, above and beyond, or just in case, or just because . . . . :thumbsup:
How do you know it's intermediate from the original post? The supercharger just needs changing more often because of what it is and the fact that it spins a lot faster then the engine.
The kit came with spare oil, you have to change it after 2500 mikes then every 7500, I have now done 10k on it and still have enough oil for one more change. Yes they have a drain line connected which you just remove the access cover in wheel arch to allow it to drop down and drain.
