I brought the Z4 out for the bank holiday weekend after a winter hibernation. She started on the button.
One of the rear tyres had been losing pressure but I couldn't see any punctures. I took it in and as suspected the tyre was leaking on the inner bead due to corrosion on the rims. The corrosion was cleaned up and the tyre refitted using a tyre sealent round the beads. I'm going to get a full refurb in the next couple of weeks.
After about 15 miles of driving 2 warning lights came on the dash
They go off after the ignition is turned off for a few mins but reappear after about 5 mins of driving. I've done a few searches and tried the lock to lock several times on the steering.
I'm thinking it's mostly likely a wheel sensor as it seems a coincidence it coincided with the removal of the wheel.
Are there any sensors on the actual wheel that could have been moved/damaged or are they attached to the brakes?
