Tracking down codes & fun upgrade!
Envain
San Jose, Ca
Just got the Wagner fmic boy what a joy to install. The cold side connection just didnt want to play nice.
This is as good as I could get it, im going to prob bring it into a shop to see if they can fit it better than I could.
I decided to go to mhd 1+ and drove around for a bit to see if I could tell of any boost leaks. Everything sounded fine for about a hour diving around, boost seemed fine too, about 10 mins from my house though i went full throttle one last time and got engine code for c6, very rough driving that last bit home.
This morning after resetting codes and flashing back to stock to test, then flash back to map 1 did some spirted driving and felt normal. aside from getting some dme codes.
Sitting at 13k miles.
plugs are new (within last 1k miles)
Im thinking the coils are original so I have replacements on order.
The power management issues, im thinking has to be either the installed parking sensors that the original owner did, or maybe mr12v? not sure there.
Cylinder 6 misfire first port of call coils, then plugs then injectors then the 'mysterious' cyl 6 misfire which is unusual below 500 bhp ish
Current violation could be anything, usually an accessory recently fitted or stock units starting to go bad..current monitoring will give a clue..
Thanks, Im assuming going to the Stage 1+ tune started this with the more aggressive map and the coil or injector couldnt handle it.
I went back to Map one, and did a few WOT couldnt reproduce the issue.
I purchased a set of the OEM Coils so we will see if that fixes it.
Would these other two codes have any effect on missfires?
On a side note, Got to go to a bmw meet and ran into this beauty.
Very common that on the N54 OTS tunes precipitate misfires obviously the more aggressive the tune the more likely a misfire ..almost always in that case it’s coils, plug, injectors, HPFP, boost leaks due to cracking, then turbo failures..
Looks like the coils was the culprit, Thanks again! Did a long drive along the california coast and she ran like a dream.
