mmm-five said:I'm using the Tracker that came with the car, on a lifetime Horizon or Monitor subscription.
Was about £700 for lifetime subscriptions, and it's still working after 6 years and 140,000 miles.
Simply because I keep getting phone calls from them to say the car is being moved without the ignition on...when it’s on the back of a lorry being driven back from the Nurburgringexdos said:How do you know it's working? What test can you do?
mmm-five said:Simply because I keep getting phone calls from them to say the car is being moved without the ignition on...when it’s on the back of a lorry being driven back from the Nurburgring![]()
Now you really need to tell us more.mmm-five said:Simply because I keep getting phone calls from them to say the car is being moved without the ignition on...when it’s on the back of a lorry being driven back from the Nurburgringexdos said:How do you know it's working? What test can you do?![]()
Just early signs of rod bearing failure driving from the petrol station to the track one morning - it was fine on the drive back to the hotel the night before, and the drive to the petrol station in the morning, but when I started it back up I heard a very faint noise from the bottom end, so drove it (very carefully) to a mechanic mate at Rent4Ring who told me to turn the engine off there & then.buzyg said:Now you really need to tell us more.![]()
Thanks for the explanation.mmm-five said:Just early signs of rod bearing failure driving from the petrol station to the track one morning - it was fine on the drive back to the hotel the night before, and the drive to the petrol station in the morning, but when I started it back up I heard a very faint noise from the bottom end, so drove it (very carefully) to a mechanic mate at Rent4Ring who told me to turn the engine off there & then.buzyg said:Now you really need to tell us more.![]()
A quick check of the oil showed LOTS of metal in there and the filter (changed 2 weeks before) was full of metal...on both sides of the filter.
So decided to leave it there and get my breakdown company to recover it (which ended up being a bit of a ball ache) - and that’s when I started receiving the tracker calls.
Was going to rebuild it with the idea of supercharging, but the engine in 140,000 miles old and it was cheaper to buy a 2nd hand low mileage one from a crashed Z4M. Posted about it on here at the time.
Unfortunately money has been a bit tight, so after buying the engine, the job has been put on the back burner somewhat until I can afford to do a fair amount of work on the rest of the car whilst the engine is out - such as realigning the clutch so that the 1st/2nd gear notchiness is removed (as it was before the clutch & flywheel change, and subsequent accident).
I keep expecting it to stop working, as I’ve read many of them do. Maybe mine is lasting longer because mine was driven a lot, and the tracker battery kept being charged?exdos said:. The car had a lifetime Tracker Monitor subscription and I never received any calls from Tracker. Tracker ended up fitting a new unit
My Z3MC is permanently connected to a trickle charger too.mmm-five said:I keep expecting it to stop working, as I’ve read many of them do. Maybe mine is lasting longer because mine was driven a lot, and the tracker battery kept being charged?
I don’t live time, I just play back the video from my dashcam to see if I recorded anything interesting.exdos said:My Z3MC is permanently connected to a trickle charger too.mmm-five said:I keep expecting it to stop working, as I’ve read many of them do. Maybe mine is lasting longer because mine was driven a lot, and the tracker battery kept being charged?
I wonder if Tracker will give us our lap times around The Ring?![]()
