what is that front bumper called ??KERMIT1970 said:
KERMIT1970 said:Well folks fitted Eibachs yesterday & very disapointed,fronts looks great as aspected but the rear has not moved . Driven the car for 50 miles to try & get them settled. Measured before & after, and same height as before ! Called Damon Tweeks to check correct application. Going to remove rear springs & send them back for Eibach to have a look. Have the part number for the rears will check first. Gutted ! :x
KERMIT1970 said:Update on Springs Eibach have had the springs back & tested. They can't find anything wrong with the springs & are correct spring for my car ! :x Damon Tweeks have been great offering to take the kit back & give me refund,but after fitting the fronts & can't be bothered removing the fronts ! So just going to refit the Eibachs back on the rear !Handling was a lot better so on the bright side.
Anyone used Eibachs on a coupe with no drop as aspected ?
