Tip to remove dome light
bigendbob
If you want to replace bulbs.
Anyone wishing to remove dome light, best method i found runaround the edge inserting a credit card in the gap between the plastic surround.
Theres four spring lugs about an inch from the ends, two front, two rear, then it pulls down about 3/4 of an inch. Press two clear plastic lugs on the right and it comes away.
