I'm getting an intermittent quite loud 'ticking' noise that seems to be coming from the instrument panel. It's happened on only two journeys, months apart, so far & tends to start at about 70mph. As I reduce the speed it comes & goes & drops out completely at just below 60mph. I'm thinking it's probably temperature related as well as speed due to it only happening twice so far. It sounds exactly like those early cable driven speedometers when the drive cable has worn through the outer sheath. I had this on my first car which was a 1969 Vauxhall Viva. I expect the Z4 speedometers are electronic though so it can't be that, but maybe something in the speedo mechanism?
All the gauges are working perfectly & the needles are rock steady. Any ideas? It's bloody annoying when it happens
