wolfgangCoupe
Hi Guys,
Calling on all zed-heads for some advice on a new issue I'm having.
As you can see from the picture, the thermostat is only showing upto a quarter way on the dial. It floats very slowly in this range, but never upto operating temp or back into the blue, even after a long run of upto 3 hours.
From some research and chat with a mechanic friend, the first port of call was possible a sticking thermostat? However there is also suggestion on the forum it could be a water pump on the way out, which is obviously significant more expensive.
Hoping for the best here but any advice would be appreciated. I'm a keen fixer so any work will be done by myself.
EXTRA DETAILS:
- I've replaced the oil filter housing and oil cooler gaskets, replacing both the oil and the coolant. Having driven around europe and doing about 4000 miles since then I highly doubt it's anything to do with this work.
- The car has had a water pump and thermostat only 40,000ish miles ago
- MODEL - 2006 Z4 E86 3.0si Manual
Let me know of any theories and I'll answer any further questions!!
Wolfgang
EXTRA DETAILS:
Wolfgang
