Paulwirral
I've had the yellow traction , brake light problem for a couple of months , on and off as it felt like it .
As my amazon code reader turned up , I scanned it and it's down to the 2master cylinder brake sensors as someone else found , pretty sure it can the the abs module as well though .
Any how , £210 and an hour and halfs work including swapping front discs and bleeding complete system and test drive it's now ok , I did this myself using ate blue fluid and a cheap self bleeder , blue so you know when it's bled through , used it all my life and it's high temp as well so the brakes may not over heat next ring trip !
I know my way around the dirty bits but even if your a novice this job is a doddle , don't be paying main dealer prices for the labour , hope this saves someone a few quid by being brave .
I'm sure there's a how to pictorial on here somewhere , I would have done one myself but posting a message is my limit on computers , I'm better with spanners and trowels :rofl:
