The common Trifector of lights
Zowen
Wigan
Hi guys,
I've been hot with the common problem where dsc, brake ((!)), and abs light shows up in amber.
I have a scanner and read the codes and this is what was shown. I didn't have it for a while until a tyre blew and it had been changed after that it was on and off and now permanently on. I thought it would be the angle sensor however it was reading the angle ok on my scanner and I'm unsure what this is saying the issue is.
Regards,
Zowen
Rotation Rate Sensor is the yaw sensor under the righthand seat. That would give those three lights if it fails. Often gets wet so stick your hand under the carpet to check.
If it was an ABS sensor on a wheel then you would have the tyre warning on in amber as well.
Apologies, I'm been sloppt recently I meant brake, DSC and low tyre all in amber as shown in the image. (handbrake on so brake is red and amber when off)
Ok. Well possibly an abs sensor on one of the wheels? Did the blowout damage one?
It was the rear near/side tyre that went it went on motorway other than the alloy itself was fine other than the tyre obviously which was split so I imagine it couldve come from that.
