Looking at that, think it may be time to change the salmon relays
Smartbear said:SV8Predator said:Smartbear said:Told you I’d read it somewhere, posted by Robbiez4 no less https://www.spoolstreet.com/threads/urgent-recommendation-to-replace-the-pink-hardtop-hydraulic-relays.3815/
Couple of screenshots, one of which shows a burnt out e89 roof motor
Yes, as explained by RobbiZ4 on P1 of this thread:
RobbiZ4 said:I would not expect "flames". The motor simply continues turning around as intended. But it gets hotter and hotter until internal(!) plastic parts will get overheated and melt away. Then the rotating unit will stop, cool down and is destroyed.
Yep, in Robbie own words the pump has been burned. I knew I’d read it somewhere.
SV8Predator said:Smartbear said:Because I’d read it elsewhere, is that ok with you?
No no real-world experience then?
I don't understand why people post their "wonderful advice" when they really don't know anything about the subject being discussed?
See Robbi's advice (above). He actually has the real-world experience.
Smartbear said:Just to reply to your rude & ignorant comment about “not knowing anything about the subject being discussed”
Smartbear said:they can burst into flames!
Smartbear said:I’ll come round & torch your car for you.
SV8Predator said:Smartbear said:Just to reply to your rude & ignorant comment about “not knowing anything about the subject being discussed”
The subject being discussed is the fact that (according to you), the pumps can burst into flames, if a fault lets them run continuously:
This has been refuted by other posters, speaking from their experience. You attempted to justify your claim by spuriously quoting RobbiZ4 who actually said nothing of the sort. Overheating and melting of internal pump components is not "they can burst into flames!".
Rude and ignorant?
