Bodyboarder
Hello … I’m going to be doing a basic suspension refresh , consisting of damper , top mounts , inner / outer tie rods , lower control arms , lower front rear arm bush’s , drop links etc
My car is a road car …but plan to do 1-3 track days a year in it . Has eibach springs on and I’m super happy with the ride height , so not looking for a full height adjustable cover set up .
What damper would you recommend? Stock type ones like sachs , as my damper are 18 years old and covered 80k miles , so even these will probably feel like an upgrade !! …or an updated damper such as the B8’s … heard so many different things about the B8’s being too hard ? Anyone have up to date experience with them . Any other to consider ?
Next after the suspension I’m looking at a lsd and some sort of brake upgrade …. I think I know where I’m headed for the lsd but what have folk done with the brakes ? Can I use my standard 325mm discs and add say a 4 pot Brembo calipers set up ?
As always , thanks for the help and info is much appreciated
