Teeny amount of APC with snow foam?
playalistic
 Reading
Car is pretty dirty in the lower quarters (oo-er) and hopefully the weather will hold out for a wash tomorrow. Was planning on putting a tiny bit of megs APC in with the snow foam i.e. 1 1/2cm of snow foam (valet pro) and 3mm of megs APC to help with the caked dirt. At that ratio I assume it doesn't strip wax?
Anyone tried a little APC with the foam at all and have any opinions?
VP pH neautral has almost zero cleaning power but does soften dirt as it clings on the car ( if that makes sense? )
When I used to use it, if better cleaning was neccesary I would add a splash of megs apc into the mix.
Yes it does help.
Dependant on the dillution rate, it will weaken waxes and or sealants regardless but only marginally.
The stronger it is, the higher the chances are.
Im using autobrites supa snowfoam which isnt too bad tbh but what you have to consider is any snowfoam that cleans extremely well will have an adverse effect on your LSP.
If im stripping a car back or carrying out correction/enhancement work, I will always use apc in the foam to help strip the LSP back and to good effect.
Autobrite have another foam ( cant remember the name ) the contact time is far longer than any other foam and alledgedly has good cleaning properties.
Might be one to take a gander at?
I have the autorbrite as well.
