Swapping to M seats
0xid0
Hi,
I want to swap to M seats, but i have two questions:
As i read, passenger occupancy sensor between pre and post are different, so... its not compatible. But... if i purchase pre M seats, i can install RHD seats in LHD car swapping each seat? i think the only problem is i lost the memory on driver's seats, really?
You would need to install a bypass sensor as well otherwise your airbag light will come on.
If you have electric bases you could swap them.
My seats are manual, and the M seats i see are electric.
But, if both are pre, i need bypass sensor?
M sport seats have suade on the inside edge of the base. This may differ for actual //M seats (as in out of an ///M
I can see this. Can you post a pic of this? Thanks!
If you are going to use lhd seats then the sensor Will be in the wrong seat.
you can swap them all you need to do is use you old occupancy sensor from the passenger seat and get a bypass plug and fit it to the yellow connector under the passenger seat in the car.
The drivers seat doesn't have a sensor as you would have to be in the seat if driving.
The way you are thinking of doing the swap,you will end with the seat guides on the incorrect side,adjust buttons
inactsessable.
