Suspension upgrade - anti roll bars / polybushes
mrlozzer
Veteran
 Geordie exiled in Wales...
Just dropped off all the various bits with my mechanic for swapping over the anti roll bars for E46 M3 stuff with Powerflex bushes
The fronts seem to be a straight swap, as all the part numbers are interchangeable with the E46 stuff. The ARB is a 26mm item (some M3s have 24mm), should this should be nicely stiff.....The rears are a bit more involved, as the M3 uses different brackets to fix to the car. Trying two different sizes of polybush for this, so will report back which ones fit the thicker bar (21mm) but the original brackets... could be useful for others in due course. Will try to post up some pics once the garage has test fitted it all...
