Supersprint Race = HP gains?
May be some gains but the state of tune the engine is already in from the factory I would suggest they are negligible. Always worth contacting the manufacturer to see what they claim.
As said, negligible. Even if it produces a few ponies will you be able to tell the difference?
My RPI's are said to produce something like 5-7hp. Now i could say that it seems to pull a bit better at high revs but i'm sure it's all in my head. It sure sounds like it produces a lot though. In the region of 150-200hp extra! :driving: :rofl:
Because they are not oem the system may not run optimally with these upgrades you may loose power as the ecu compensates.
Although having a NA car a chip won't do anything generally but it may make the car run more optimally and you might see a couple of HP.
I'm with Tom on this one, actually. I think if anything, the exhaust change would likely cause a loss of power, not an increase.
I had Supersprint Race exhausts on mine.
As said above, no i don't think so.
It certainly SOUNDS like i gained about a Golf GTi's worth of extra power though! :D
