Sump Gasket
Evening
Just about to have the sump gasket replaced due to a small leak that has developed, as this involves removing the subframe could anyone recommend any other gaskets than I could replace at the same time as most of the cost in in the labour so makes sense to do anything I can while shes in bits.
Many thanks in advance.
Not a gasket but when I had my rod bearing shells replaced at 78K miles my engine mounts were absolutely knackered, so it would be worth checking them for wear.
