Hi
I recently purchased a lovely 2003 3.0 Z4 which I absolutely love.
However at the moment it's more of a love/hate relationship!
I had problems with the drivers door not opening from inside or out, which by way of searching this forum, I managed to fix after finding the problem was the plastic clip that the cable locates into was broken.
At that time, i was able to open the door "slim jim" style with a long metal ruler, by either nudging the plastic fitting on the bottom of the cable, or pushing the release lever that the cable operates.
I then cable tied the cable to the clip, to secure it.
All was well for a couple of weeks.
Today though, the door won't open again, and no matter how much i push the lever with my trusty ruler, the door wont budge.
With my limited knowledge, I suspect this leaves the latch mechanism itself at fault? I saw a post about the latch needing lubricating, but when I last had problems, it was fine, and it got a squirt of grease anyway.
So my first problem is how on earth do I get the door open to diagnose/fix it ?!
I don't even know if it is possible to get the door card off with the door closed as it looks like the dash fouls it at the front. And even if I can remove it, would the seat have to come out to get proper access to the door?
If anyone can shed some light on this, I would be so very gratefull!
Thanks in advance.
Thanks in advance.
