BMWZ4MC said:I found (rather suddenly) that the settings recommended by KW were too firm for road use (as I told you). I've backed them off a bit, but there remains adjustment in both directions from my current settings. I've left it set at what I feel is likely to be the optimal setup for track use so I can learn the behaviour of the car again having upgraded so many parts at once. Once I better understand how the car handles in a variety of conditions and on different surfaces I'll make incremental adjustments and test these on both road and track.
With Clubsports; rear topmounts; RTAB limiters; camber plates, strut tower reinforcement plates and a strut brace; stiffer ARBs; competition engine mounts; and 19" wheels the car is really very stiff now. There is a modest increase in conducted nvh from the engine and a huge increase in conducted road noise. Painted road markings break teeth and the car is skittish on really badly made country roads (all improved with 18" wheels). Interestingly, the ESP doesn't activate any more often than with my previous Eibachs and OEM dampers and does so less than with the full OEM setup. At present, the best way of coping with rough surfaces is to hold the wheel lightly allowing it to self-centre and trust the car to grip. I'm sure when I soften the damping it will be more comfortable, but I don't think it will be as smooth on A roads as you've made yours.
My preferred tracks are short and technical rather than having long sweeping high speed bends, so this setup really suits me. However, I wouldn't recommend it to someone who's looking to improve their daily driver or weekend road car.
We really must meet and compare notes at some point (although I'm currently writing an MSc thesis so it will have to be later in the year).
Pretty much perfect i don't need to add anything....
