Streaming options
jamesditchy said:
Tcochrane92 said:
Does anyone know where I can buy the Dice Media bridge from? Not available on Amazon or am I looking for the wrong thing?
I'm having the same problem. If you find where to get them will to u let me know
Your only bet is eBay. The product was taken over by a company called Audiovox but is apparently no longer available. The last firmware update (which I installed) was 2015 ! To be honest the technology is a bit long in the tooth and you would be entering a lottery buying one unless you had a guarantee of it working.
JINGLE said:
If I have the basic 6 speaker set up, and no sat nav screen, but I do have MFSW controls, what’s the best route for me to go down?
I had the same setup and installed a pioneer head unit and the steering wheel adapter works great.
That is true about the audiovox, i got mine off ebay after someone removed it from their zed :thumbsup:
I’m swaying towards an aftermarket head unit, do the steering wheel controls work the music on your iPhone music when playing? (Rewind/forward and skip etc?)
What adapter do you have? I'm having cut outs with my autoleads one.
Honestly wish I'd bought a zed without nav as the aftermarket headunit is miles better than any of the workarounds
I have the connect2 adapter which I think is actually the same as the autoleads one but rebranded. I do have a slight intermittent issue with losing connection to the steering wheel controls.
When it is working then yes I can change track on Spotify or another music app on my phone. I use the USB quite alot too. I have a 128gb stick with 50gb of music on it.
The steering control issue is annoying if it goes off but it's not difficult to skip track on the head unit buttons. The pioneer seems a good unit and was easy to install
Exactly my issue, maybe one for a different thread? I've found restarting the adapter fixes it, support can't figure it out and I'm on my second one, did get almost a full refund though and still have the product.
I plan to wire in a switch to enable turning it off and back on again, though it doesn't happen very often - when it does it's usually on a long journey!
Does the auto leads adapter have separate power connector?
The connects 2 just plugs in to the harness so I'm not sure how to reset it
