Strange thing happening with front indicator
jamesgarbett
South Manchester
Last couple of days the bulb out warning light has been on intermittently
Just checked all the lights and the driver's side front indicator "hockey stick" is coming on (constantly) when the side/head lights are switched on
It went off after a few seconds and the warning light in the dash went out
Any idea what's causing this?
Thanks James
Is there any water or condensation in your headlight? If the seal has perished it could be letting moisture in causing a short. Also, check the connections to make sure they're all fully pushed in.
Andrew.
I had a blub warning appear, I checked and I had no side light and my indicator was on, then it started working again for a few days. I thought it was a lose conectiontion or something, but before I could check the bulb went so I replaced it and all is well now.
