Strange lead on negative terminal
Pipkin38
Hi Chaps
I have found a 3 pin lead and plug in the battery bay of my 23i
I thought that maybe I had dislodged it so I have reconnected it to the negative terimal.
Seems to make no difference......yet
So the question is what exactly does it do?
Previous threads have mentioned an ability to disable parts of the alarm during transit but this lead is more substantial and plugs into the terminal itself
Unfortunately I still havent figured out how to post a photo after the photobucket fiasco
Many thanks
Pip
If it plugs onto the something like a black box built onto the negative lead terminal it will be the battery monitoring system, the car probably has Stop/Start and an AGM BATTERY. The car uses this to monitor the state af the battery so it doesn't switch the car off when you pull up if the battery won't start it again.
Stuart
https://1drv.ms/i/s!AqClAKN8Dh4zgzXPwHAHJiFng3VN
Many thanks stuartt
Not sure if the above link from one drive is working
Pip
Many thanks stuartt
Pip
Yup it works sort of, have a read of this thread and it will explain how to upload pics :thumbsup:
http://www.z4-forum.com/forum/viewtopic.php?f=5&t=88363&hilit=Photos
Stuart
