Every 3rd or 4th time the passanger side door fails to unlock when opening the car from the key or simply pressing the lock / unlock button in the car.
On occasion the little bugger will work just fine for the entire day (sometimes even two) but more often than not it doesn't unlock.
I don't know how the central locking system works but it almost seems like it is a hydrolic based system and not enough pressure is being sent to the lock. If it fails to unlock once it will most probably unlock just fine the next time which is what is leading me to believe that it is hydrolics based i.e. enough pressure builds up after failing to unlock once.
I am half tempted to open it up and have a look, perhaps there's something trivial that could be resolved without having the dealer look at it which I'm sure will result in hundreds of pounds of expense.
Has anyone had a similar issue?
So, I just put my key in and lock it when it happens!!!! Let me know if you find out or if I do if I can ever get to the dealer.
