Sticky steering
Mine also creaks a bit when I'm pulling off our drive.... don't even want to consider stripping and re-greasing as don't know if it's easy to do yourself? Can this be done in the cockpit by removing panels around the steering??
I found a DIY on another forum where a mechanic installed a grease fitting in the EPS unit and has apparently stopped his sticky steering.
Here: http://forums.bimmerforums.com/forum/showthread.php?t=1896932
This is good news indeed. I'm slightly concerned about what may happen if you force too much grease into the case. But to install a proper relief port, you probably have to remove the column. The fact this mod can be done in situ is brilliant! Looking forward to more success stories.
