Stereo has lost power
OK apologies in advance as i'm a car luddite..
Problem is no power at all to the Pro stereo when i start the car.
I tried to look for the fusebox but manual wasn't at hand and not much on Google.
Other than that and paying £99 to BMW for the hour to check, any ideas how to fix or a roadmap to the fusebox to check please?
Thank you loads,
Simon
So the fuse box is a PITA to get to but has a fuse map inside it. You need to look under the passenger side of the dash, there are three screws to remove and then you pull down the trim, there's a single screw to undo and then pull down the fuse box which doesn't move easily. Your owners manual shows how but makes it look easier than it is. There are so many cables that have set in position since the build that it's quite tough to move without feeling like you're going to break anything.
