Steering wheel make noise
Znoober
As some of you fellas know that I just got my 1st Z ever , today I took it for a spin after done with clean up and gets all things back to working order . My steering wheel is making noise when I drive around the block and try to make a hard turn , and it’s even more when I do parallel part .. so I when to google and you tube it then I found 3 solutions for it , grease the driver side steering rack , drill hole on the steering column and grease it and steering motor spacer adjustment… so which one is the best solution ? Should I do all 3 ?
Has the car been sitting around for some time, my steering will groan for a while, after being not driven for a few months.
Take it on a decent drive and see if that helps.
