daz05 said:After some research, it looks like this official BMW item may be an option. It's an E30 wheel badge and is adhesive 45mm, going to double check it fits then hopefully get that. Only £5.![]()
P/n 36131181082
Carbon stuff is not to my taste. :thumbsdown:
Shidevil said:Mate, stick a badge on top of it. I did this for my carbon look and you dont know there is a badge underneath, job done!
Lucy said:Shidevil said:Mate, stick a badge on top of it. I did this for my carbon look and you dont know there is a badge underneath, job done!
I did this too and you couldn't tell there was a badge underneath. Cheapest and simplest option!
bradmarsh1989 said:I replaced my wheel centre badge today with the carbon ones.... It's tricky to do without seriously damaging your wheel or accidentally deploying your airbag into your own face, trust me I s**t bricks prying the metallic one out...
Basically it's crimped into the steering wheel and these little metal clips have to be severed for the original to come out, if you stick a cheapo badge over the top there is a chance with time the badge wont stick to the contours of the original and look horrendous... after much prying and praying i did get the old OEM badge off and applied some foam into the gaps that you will see that now are present on the steering wheel to provide a flat surface for the new badge to go in place... I then applied some epoxy resin (very small amount) to the badge itself and gently placed it in place of the old badge... cosmetically it looks fine (pics soon) but it is not as strongly held in place as the old badge for obvious reasons, though I dont see any logcal reason how it would come out naturally... unless u decide to take a corner as + 11G...?
markeg said:Wonder how fast will it be projected when the airbag goes off?
Just a thought....
Tapatalking...
