Hello to all,
I bought a z4 30i a year and a half ago now, I'm super happy with it and for the first time I have a problem on it. The steering works intermittently and I have a fault (a54b), which indicates that the car cannot communicate with the steering motor. I've seen this problem is common on this generation.
So I'm hesitating between taking it apart and having ECU Testing fix it for £400, or buying a used motor for up to £100 (I've found the motor part number and apparently it's the same as on the 1 and 3 series).
Do you know if this second solution is valid? I mean put a 3 series or 1 series engine on the steering of my z4 e89.
Here is the motor reference: 7802277265
Thank you all for your advice
