A friend had an issue with a torque sensor fail code in his E85.
We have cleaned, adjusted, recalibrated the steering angle sensor and swapped the EPS motor.
Eventually agreed it would have to be a column change.
Just completed it this afternoon. Cleared all the codes and started it up. Immediately got the yellow steering wheel light and no power steering.
Sport button still works.
Codes as follows (all of which clear ok, but make no difference, and come back the next time you start)
611C Steering Torque (this was the original code too)
0B Sensor/vehicle allocation incorrect or not available (under 'Steering Angle Sensor')
Data stream for Steering angle sits at -1439.24 and doesn't change whatever you do with the wheel.
Do I need to code the SAS? Or calibrate it? I'm a tad lost.
I was led to believe it would be a plug and play thing as I've changed the complete column, motor and SAS all together.
