brawnyblue
Since Sunday my 2004 2.5i has had issues starting up.
I was away for a week and when I came back I encountered the following issue
- The engine does not want to start up at first. I turn the key and the engine just chokes a few times. Usually, the second time I try while pushing the accelerator the engine will fire up
- Once the engine is hot and and the car has run for a while the issue is gone. I can switch the engine on and off without any issues
- I noticed that while the engine is trying to start up all lights quickly come on and off in the same rythm as the engine chokes
- I drove for a while to make sure the battery would be charged (in case it was just flat) and the problem was still there the next morning
- There are no other issues, no misfirers, no noises, etc.
- Just want to mention that while I was gone, I left the light switch on. My lights do switch off automatically though so I don't see how that would have drained the battery. Even then, the battery should be charged again now.
- Also, I am able to turn on lights, open the car and turn on radio while the engine is off (I only tried this for 30 seconds or so). So if it is a battery issue, the battery is not completely dead
Any idea what this could be caused by?
