Standard OEM Bluetooth Headunit - Installed in your E89
AnubisZed
Lincolnshire, UK
What I'm selling here is the upgraded standard (ie; non-iDrive) headunit, installed by myself, fully fitted and coded to your Z4. If you only have the base headunit at the moment and think the sound is a bit "flat" and you can only turn the volume up so far then this is the upgrade you need.
If you already have Bluetooth then this is not for you!!
What's included....
1 x Professional headunit (bought brand new only a couple of years ago) with built-in Bluetooth and USB control.
1 x USB/AUX socket for the centre console (brand new)
1 x OEM microphone
1 x Upper steering cowl (to house the microphone)
+ associated wiring.
I'll install it and code it. This will be at my home in Grantham, Lincolnshire.
The install will give you the upgraded headunit (better sound over the base stereo) which has Bluetooth for calls, USB control for either an iPod, iPhone, or memory stick which you'll be able to control via the steering wheel buttons and will display track info on the headunit screen. You'll be able to use the phone button on the steering wheel to answer and make calls as well as the voice button, also for making calls.
This is the set-up out of my e89 I installed a couple of years ago, it is in full working order and has been a great addition to my car since I put it in. This is a one off special, I can fit these to order but this particular one is my own that I'm removing.
For this I'd be asking £250 which includes everything (including new parts where I'm keeping some parts for my new install, and my time to fit and code) :driving:
