Squeeeeeky
dragon
Squeaky driver's window when half down.
OK for the first bit, then the noise.
Rubbers dry due to heat or something else.
Anyone suggest please.
No, but will buy and try. Halfords or special?
To touch, the rubbers feel pliable and I just wondered if there was a known problem.
Have cleaned the glass with AG glass cleaner and it has helped, so hoping it is just the rubbers.
This is the stuff Markeg is referring to used it myself and works a treat :thumbsup:
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=+gummi+pflege+&_sacat=See-All-Categories
The squeek is back. Twelve months since last time. I now think it is due to the increase in temperature possibly expanding the foam soundproofing in the door. The glass is not being marked but if I spray on glass cleaner, I can see lines where it is rubbing something on interior side?????
regulator prob on its way out, you might try extending its life by greasing up all the pulleys and cables, i would try putting a bit of silicone on the edge of the glass front and back to see if the creak is coming from the runners , everything else needs the door taking apart.
Sounds much more like the glass rubbing against rubber or foam. The window works OK it is just the terrible squeek. Have put some silicone on the glass and can just see the very faint streaks which rund diagonal from the front to mid way
