ionofchios
Hi guys,
I’ve just got hold of a 12/2006 3.0si Coupe (e86). I’m going to replace the front suspension and wishbones, and add BMW strut tower reinforcement plates between the underside of the tower and the strut. The car has the M suspension option.
I was thinking it might be a good idea to add some extra rust prevention between the tower and the reinforcement plate, since I guess water might get up in their. Any recommendations for what to use?
What, actually, are the BMW part numbers for front and rear springs, given that my car has the M Sport suspension option? RealOEM is missing these for some reason. What are the springs specs, meaning length and whatever else is important? I understand that the M suspension is 15 mm lower than standard, and I want to keep it like that, as BMW intended, and I certainly don’t want it lower. Anyone know any good aftermarket springs that are a direct replacement for the originals?
I’ve come across 2 potential part numbers for the front springs which some sites think are correct: 31336760622 and 31336760623. Are either of these correct, and if both are okay, what’s the difference?
Will be adding Bilstein B6s all round - but I don’t yet have any questions about those ... except maybe whether bump stops are, or are not, needed
