tiglon said:You'd bloody hope they checked everything properly!
The odd thing is, I've checked the height 4 times today, the first 3 times it was passenger rear that was higher, now its drivers side rear that's higher and passenger rear is fine :?
B21 said:tiglon said:You'd bloody hope they checked everything properly!
In that case it’s likely the springs are binding on the body of or parts of the damper…..
Were the springs explicitly approved for the Electronic Damper version?
tiglon said:B21 said:tiglon said:You'd bloody hope they checked everything properly!
Specifically advertised as fitting 35is... have I been monumentally stupid here?![]()
B21 said:tiglon said:B21 said:In that case it’s likely the springs are binding on the body of or parts of the damper…..
Well looks like the spring is binding at various points…maybe it will settle down with use…..how’s the ride …have you tried various surf and speeds?
tiglon said:Busterboo said:How much was this, please?tiglon said:... and had a set of Eibach springs fitted ...
The springs themselves were £150ish from Autodoc, then I made the mistake of not getting an estimate for the fitting so they charged me £540, apparently it took them 6 hours?!![]()
Pretty sure that in 6 hours I could learn how to do it, go buy the tools, change the springs myself, and have 30 mins spare at the end to make myself a nice sandwich.
B21 said:Sounds like they didn’t assemble the new springs correctly…if the springs were ordered as a pack than re-assembly is the most likely cause..unless that damper (on the broken spring) was compromised..I assume at that price they would have checked everything perfectly…
Nictrix said:B21 said:Sounds like they didn’t assemble the new springs correctly…if the springs were ordered as a pack than re-assembly is the most likely cause..unless that damper (on the broken spring) was compromised..I assume at that price they would have checked everything perfectly…
If its the rear that isnt sitting properly there isnt really any assembly involved.
The spring and damper are seperate from each other.
Basically to fit the rear spring almost all thats needed is to jack the car up, remove the wheel, undo the bottom damper mount and then while levering the wheel hub,disc etc down pull out the spring. To install lever the hub,disc etc down and put the new spring in place.
