sport button
It makes a considerable difference to the speed of shift changes on the SMG as well.
Almost to the point where you have sympathy for the car as it bangs itself into each gear with a thud.
Probably drops the 0-60 by 0.1 or 0.15 secs over a manual 3.0i I would guess.
GAZA62 said:
Makes mine come alive the car feels much lighter and the steering feels light (even though they say it makes the steering heavier ) as does the throttle but its costing me more in petrol because i drive in sports mode a lot.
I notice the difference more when i switch off sport mode the car drones more and feels heavy as does the steering plus the pedal feels very heavy.
The steering is meant to be heavier with the sports button pressed, not lighter.
Never drive mine without the button pressed, more noticeable when moving at a pace. 8)
Noise from exhaust change because there is thirth pipe connected to 'double' exhaust which's valve open after pressing sport button and all this will deliver more noise straight from engine ....
Not sure where you heard this but it isn't true.
I don't ever drive with the Sport button off anymore. The steering is ridiculously light with it off and it's much easier to heel-toe with it on. It also means that less pedal travel is required to hold the car at a steady speed on the motorway.
Ok my apologize...
Edit:
In rear exhaust silencer there is inside 3th pipe.... in which, after activation of the sport button exhaust gases begin to flow through... that is why some of the owner mentioned` also different exhaust note.
Dr.Gonzo said:
Ok my apologize...
Edit:
Still no, there isn't. There is no 3rd pipe or anything other than standard. People have cut into back boxes, there's no trickery in there. Honestly the exhaust note doesn't change, it's a placebo effect. Like thinking the sport button gives you a quicker 0-60.
The E85 sport button only does two things on a manual, speeds throttle response and weights the steering, on an auto or SMG box it also improves the gearbox responses. No exhaust flaps or noise changes, no engine mapping or power gains, no suspension changes.
Other BMW models do include some or all of the other features in sport but on the E85/6 it's a placebo button and wonderful man toy.
The attached technical files explain all the CAN BUS links and much much more (It's a Latvian site but Chrome will auto translate)
http://www.bmwclub.lv/files/04c_MS45_DME_Part_4.pdf Sportbutton etc
E85 M54 technical files http://www.bmwclub.lv/index.php?MODE=bmwdocuments&MISC=Z4
Can a "Sport" button be easily retrofitted in the facelift 2.0L models?
Don't think the 2.0L models have Sport button as baseline.
