flimper Veteran Hampshire Nov 18, 2014 #1 After doing a little inspection on the M today I noticed the door rubber has a small split in it by the kick plate :evil: Can this be superglued or do I need to buy a whole new part? Expensive if so
flimper Veteran Hampshire Nov 18, 2014 #2 Found this, might not be as bad as I thought http://www.zpost.com/forums/showthread.php?t=786370
flimper Veteran Hampshire Nov 18, 2014 #3 Not sure which part though... http://www.realoem.com/bmw/showparts.do?model=DU92&mospid=49422&btnr=41_1710&hg=41&fg=40 http://realoem.com/bmw/showparts.do?model=BT93&mospid=49345&btnr=51_4940&hg=51&fg=55
J jan_tekin Senior member Kent Nov 18, 2014 #4 What side are you after, I have a passenger side one from a coupe that your more then welcome to. Used the drivers side to replace mine which was split as well, had to cut it as i don't have a roof Part no 1 http://www.realoem.com/bmw/showparts.do?model=DU92&mospid=49422&btnr=41_1710&hg=41&fg=40
