speaker upgrade info request
alfamale
I’m planning to upgrade the speakers on my 06 coupe, i believe i have the 6 speaker system as i definitely don’t have subs in the back panel
Does anybody have a list of speakers that fit the OEM holes or the dimensions of what will fit? also can you confirm the six speakers are 1 in left footwell, 1 tweeter in lh door post and 1 in lh back panel and the 4" grill in the door has nothing behind it, and same on rh side.
I’m away at the moment so cant go and check and ideally would like to order parts to have ready when i get back, as its the coupe i don’t need to use the rears as much so plan to put descent speakers in Footwell and door, i think its 6.5" in footwell and 4" in door but would like it confirmed before i get the plastic out.
any comment on what i plan are most welcome, the existing system is loud enough and the base is ok, what i want is a bit clearer as i think the oem set up is a bit muddy or muffled, i had my last car updated by just changing the door speakers and it made a huge improvement.
OK i can confirm 6.5 inch for footwell
found this very usefull
http://www.crutchfield.com/app/car/carselector.aspx?vb=Y&ss=Y&g=266150&sl=Y&lp=%2fApp%2fProduct%2fCategory%2fGroupMenu.aspx%3fg%3d266150%26tp%3d9&
put your car details in and it tells you what fits and if any adapters are needed.
Hi got the same set up as yourself and looking in upgrading as well if i find any info i pass it on
think of just upgrade speakers and leave the head unit alone!!
many thanks :)
Alan
had a look last weekend, 6.5 will fit no problem but you need an adapter ring, OEM's are 6.3/4 with a non symmetrical bolt pattern, i may add some 4" to the empty door grills as well if just the footwell speakers don’t solve the problem
Hi
I've also got the standard 6 speaker setup and I've just bought 2 x
http://www.caraudiocentre.co.uk/product_m-in-phase-xtw6_p-24087.htm for the footwels, and 4 x
http://www.caraudiocentre.co.uk/product_m-in-phase-xtc42_p-19733.htm 2 for the doors and 2 for behind the seats.
Going to keep my standard head unit, but I may fit a couple of bass units into the opening behind the seats later if the bass is still not good enough, not going for an amp yet - I'm after quality not mega volume.
Just got the panels off from the footwells and removed the speakers there and the new one isn't a direct drop in, no matter, I'll pick up some 6mm MDF tomorrow and make an adapter plate.
Not looked at the fitting for doors or rears yet.
i fitted 87mm speakers in the door, this made it easy as the speaker missed the 3 bolts on the back of the door panel, i used the plastic blanking plate thats bolted to the back of the door panel as an adapter by routing out the middle, the JBL speaker has only 2 fixing lugs, one picked up with one of the 3 bolts and the other i used a countersunk bolt to the plastic plate, took the feed from the tweeter wire as there are no spare wires in the door
door speakers make a big difference on the 6 speaker system, also when i fitted the JBL footwell speakers they came with a selection of adapter rings which i used so no mdf work.
How do you get the new door speakers to work? Is there no cable routed for them?
Hi Gaptek
How did you get on with your install? Were the In Phase speakers any good in the doors? Im debating wether to go with them or try and get some components as im worried the tweeter in the Inphase will "interfere" with the tweeters in the door and sound rubbish.
In response to Rich-hill above, I think he must have tapped into the tweeter cable as apparantly its a full range signal that can feed a standard speaker in the door.
Dan
This link probably replicates information in links already posted, but who knows, someone may find something additionally useful. http://www.z4-forum.com/forum/viewtopic.php?f=2&t=41138&p=579722
