spark plug gap
06z4m
can someone tell me the correct spark plug gap. cant seem to find it. should normally pre gapped but i always like to check.
thanks :driving:
If using an iridium plug they are pre gapped and not usual to change them. I found the denso iridium power plugs worked well :)
i gapped mine.... 2 of them were incorrect, i can dig out what they were gapped too if you want, i recorded it on my service book. Always good practice to check.
thats why i always check. thanks :thumbsup:
for anyone interested i have the bmw plugs. part # 27772 bmw box. ngk plug #dcpr8ekp dual elctrode type. gap on the side elctrodes is .018" or .4572 mm for you metric guys :driving:
Well worth a check tho as they easily get out of tolerance with slightest bump.
I thought you were not meant to adjust iridiums as the latest technology very small diameter iridium alloy electrode is too easily damaged by the very old tech feeler gauges we all know and love?
Found this regarding gapping iridiums...
http://www.ngkntk.co.uk/index.php/technical-centre/spark-plugs/spark-plug-gap/
On socket size I'm guessing at 14mm but I don't have an M (my socket set has a variety of thin walled plug sockets with the rubber inserts so I just try them until I find the one that fits). Best to use a special thin walled one with the long reach and rubber grab insert rather than a bog standard socket.
Of course the hamfisted should probably think twice about adjusting the Iridiums, however - they are not specified for our engine officially, which means they don't come with our trusted 0.9mm gap.
They are perfectly adjustable if you take a bit of care.
you can with a small pair of needle nose pliers etc just dont pry on the center electrode. i have had to do it because of some coming with the wrong gap.
outside hex is a 5/8". thread sizes is 12mm.
the ones i got are not fine wire but double platnuims dual electrode. came in a bmw box so guessing they are the oe type plug
no fit state said:
There's a bit of a difference between 5/8 and 12mm.
outside hex is 5/8" head to remove plug so need a 5/8 socket to remove/install thread size on the plug is 12mmhttp://www.ngksparkplugs.com/products/spark-plugs
Personally, I'd never adjust the gap on the spark plugs in the S54 engine, I know of 2 cases of these spark plugs breaking losing the parts inside the cylinders even though they had never been adjusted (i.e. metal parts not been bent). One of these incidents happened to a friend I was driving with en route to The Ring, and he had to drive the last 100miles on 5 cylinders. Fortunately, a scope showed that the metal bit had been blown out of the cylinder with no damage, but it could've been different.
i hear you but couldn't that happen on any engine??
with anything mass produced there will be x amount of bad ones git through. but it would suck to have a spark plug faliure like that.
i once pulled a ngk laser cut iridium out of a aprilia that was running poorly. it unscrewed but just the center came out! threads still in head.
plug was never gapped.
cheers :driving:
