spacers
Rusky
 Cambridgeshire
So car is running on eibachs and spacers of 20mm rear and 15mm front have been suggested. My question is are there ones i should look for as the better option and also is it going to diversely effect the way the car handles?
Thanks all. :thumbsup:
Whatever you choose, you want hub centric. Most people state H&R as a good brand for these. You'll also need extended wheel bolts. Should come with if you buy new.
There are some thoughts that spacers will put more stress on things such as bearings as you're technically extending the wheel away from them so the force would increase. Saying that, loads of people run with them and haven't had issues. You could potentially get rubbing depending on what wheel and tyre setup you've got.
I'm also looking for spacers but they are currently the least of my priorities ATM.
H&R didn't come with bolts when I bought some.
Handling wise if you have a wider track increase on the rear then you'll get more understeer. That's why I have 10mm all round.
Hi Rusky, Eurocarparts currently have 10% off H&R spacers and it looks like they do a kit with 15mm & 20mm spacers with extended bolts.
