Source for CDV
Si.
 Consett
My can in in for an MOT in March so thought I might get the CDV replaced at the same time. Does anyone know of a UK source for getting the upgraded replacement CDV?
You could modify yours, takes only a few mins? Either drill the restrictor out, or punch it out
Or just remove it all together....?
Having someone just remove it for you is your best bet. If you haven't had the brakes bled in the last year or so, have them bleed the clutch and brakes for you at the same time.
Hi, It will hopefully be quite evident when you are doing the job, that you can just remove the CDV and assemble without it. It is like an add on part, if you get my meaning.
