I know the sound mod has been covered a lot before, but as a new member, there was an awful lot to read to get to the bottom of what to do and what it achieved. So I thought I'd write this new post to inform new members of how simple this mod is and an example of the noise.
For starters, this is only applicable to the 3 litre models, as they have the sound generator pipe which pipes engine noise into the cabin. This pipe has two foam inserts which sort of buffers/softens the noise. The general consensus is that only the foam insert at the cabin bulkhead should be removed, otherwise its too loud. I would agree with that.
The easiest way to do this is remove the panel under the glove box (only two screws) and pull out the foam from the end of the pipe, as shown here in the photo.
Its a 2 minute job. I also changed the pollen filter while there (it was full of leaves).
The results are fantastic. The car sounds great when the revs get up, yet is still quiet when driving slowly...errr normally.
Listen to the sound here.
I was considering if I should change the exhaust back box, as the Z4 was too quiet, but this simple mod has given me what I wanted - a big smile on my face for no cost!
